Tdskip |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,686 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None ![]() ![]() |
I want to remove the wiring harness from the 1971 donor car that I have, and was hoping to get some advice on do’s and don’ta when going after that.
Thanks! |
Specracer |
Member ![]() ![]() Group: Members Posts: 100 Joined: 27-March 17 From: SE Mass Member No.: 20,970 Region Association: None ![]() |
I too did this recently, Only connector I had to take apart is the headlight socket.
Also your removal point is just behind the shifter. Thats as far as you will be able to get the fuse panel. |
Tdskip |
I too did this recently, Only connector I had to take apart is the headlight socket. Also your removal point is just behind the shifter. Thats as far as you will be able to get the fuse panel. How do the headlight connectors come off? I must be missing a disconnect point, is it the plastic casing? |
Lo-Fi Version | Time is now: 26th June 2024 - 03:02 PM |
