mtndawg |
Member ![]() ![]() Group: Members Posts: 414 Joined: 26-January 09 From: Granite Bay, Ca Member No.: 9,985 Region Association: None ![]() ![]() |
I have a 1975 2.0 car that had parts added from other 914's, 911 and even VW van resources many years ago by other owners. It's occurred to me today that according to the part number this shroud might be from a bus. I took this engine out of the car along with the sheet metal and heat exchangers and everything seemed to fit. Here's the question... Can I use SSI 2.0L heat exchangers with this if I switch out the other heating connection components for early 1.7 or 2.0 parts? I don't heat exchangers yet so I can't check the fit. I hope to eventually get my hands of SSI HE's.
Attached image(s) ![]() ![]() ![]() |
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,107 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
NONE of the 75' gear except the heat valves will work on the backdate. Branch ducting, j tubes, maybe the elbows, muffler hanger bracket (heat exchanger specific), warm air guides.
Earlier version Warm air guides. You have to be careful. The driver's side is side-tail shift specific. Pass side is common. |
Lo-Fi Version | Time is now: 23rd June 2024 - 02:04 PM |
