mtndawg |
Member ![]() ![]() Group: Members Posts: 414 Joined: 26-January 09 From: Granite Bay, Ca Member No.: 9,985 Region Association: None ![]() ![]() |
I have a 1975 2.0 car that had parts added from other 914's, 911 and even VW van resources many years ago by other owners. It's occurred to me today that according to the part number this shroud might be from a bus. I took this engine out of the car along with the sheet metal and heat exchangers and everything seemed to fit. Here's the question... Can I use SSI 2.0L heat exchangers with this if I switch out the other heating connection components for early 1.7 or 2.0 parts? I don't heat exchangers yet so I can't check the fit. I hope to eventually get my hands of SSI HE's.
Attached image(s) ![]() ![]() ![]() |
JFG |
Senior Member ![]() ![]() ![]() Group: Members Posts: 686 Joined: 7-April 16 From: Wales Member No.: 19,869 Region Association: None ![]() |
Apologies for the hijack.
The two little flaps at the bottom of the shroud, why? If i understand correctly with these shut more air would pass through the cooling tin thus improving head cooling etc? |
rgolia |
GeoJoe ![]() ![]() ![]() Group: Members Posts: 705 Joined: 5-February 10 From: PA Member No.: 11,329 Region Association: North East States ![]() ![]() |
Apologies for the hijack. The two little flaps at the bottom of the shroud, why? If i understand correctly with these shut more air would pass through the cooling tin thus improving head cooling etc? But they only close when the engine is off or am I missing something. What are they for........someone has to know? |
Lo-Fi Version | Time is now: 23rd June 2024 - 01:51 PM |
