Turbo for a 914..., this may work |
spare time toys |
Nov 9 2004, 01:33 PM
hooked on grilling food. Group: Members Posts: 4,059 Joined: 3-April 04 From: West Plano Tx Member No.: 1,884 Region Association: Southwest Region |
Check www.ststurbo.com they put it away from the engine. I would think it would have a big turbo lag. (IMG:style_emoticons/default/huh.gif)
Jake Raby |
Nov 10 2004, 12:07 AM
Engine Surgeon Group: Members Posts: 9,398 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
That stock cam is the big limiting factor, since it bleeds so little CR away..
I'd run no more the 6 PSI to be safe... No head gasket is gonna help ya here... I'm working on an inconel filled O ring for the cylinders to cure this issue, but only testing will show if it will work with a cast iron cylinder. They were designed by Porsche for the 102mm cylinder which was of course aluminum.. Its worth a try! |
Lo-Fi Version | Time is now: 25th September 2024 - 11:00 PM |
