Ricer rims? |
Ricer rims? |
Brad Smith |
Nov 10 2004, 12:35 PM
Newbie Group: Members Posts: 45 Joined: 29-October 04 From: Fort Worth, TX Member No.: 3,029 |
A newbie question:
Are there adapters to put "ricer" rims on the 914? There are literally HUNDREDS of sizes and styles available, but alas, in 4x108 bolt pattern. I realize it would probably be a spacer arrangement with the spacers bolted to the existing hole location and studs or lugs in the spacers... the question is, are those available? I also realize it would probably only work on a car with flares... ok, no big deal. If they aren't available, I can get a friend to make me some, (he has a lathe, mill, etc at home) but wanted to look for commercial products first. Brad |
Joe Bob |
Nov 10 2004, 05:39 PM
Retired admin, banned a few times Group: Members Posts: 17,427 Joined: 24-December 02 From: Boulder CO Member No.: 5 Region Association: None |
QUOTE(Mueller @ Nov 10 2004, 12:43 PM) not made correctly or some other issue???.....a one or two inch adapter should not come loose any more than your wheel bolted directly to the hub if properly torqued :smash: Made in Germany hub centric 3 inch models....cranked down like a MOFO....two on each side came loose, even lost one nut....yanked them off and dug into Mikey's parts drawer and installed the longers studs that I ordered but never got around to installing..... |
Lo-Fi Version | Time is now: 25th September 2024 - 11:04 PM |
