simonjb |
KiwiMan ![]() ![]() ![]() Group: Members Posts: 563 Joined: 18-October 16 From: Stamford, Connecticut Member No.: 20,505 Region Association: North East States ![]() ![]() |
Can someone tell me what goes in/through the rectangle you see here in the engine tin??
Spoke |
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,994 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None ![]() ![]() |
If the hole isn't blocked off it should be to stop the cooling air from escaping to the engine compartment instead of going past the cylinders.
McMark |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,179 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None ![]() |
If the hole isn't blocked off it should be to stop the cooling air from escaping to the engine compartment instead of going past the cylinders. This hole doesn't enter the cooling air section of the tin. It just passes from the bottom to the top. So, plugging it will stop hot air from travelling up from underneath, but I'd hardly be concerned with that amount of air. Leaving it open shouldn't affect anything. |
Lo-Fi Version | Time is now: 26th June 2024 - 01:38 AM |
