Greenguy |
Member ![]() ![]() Group: Members Posts: 51 Joined: 29-December 06 From: Clovis, CA Member No.: 7,402 ![]() |
It’s good to see the board alive and well, I've keep track but haven’t posted in a long time. The reason that I’m back is that a reoccurring pain in the neck problem came back and the 914 has been parked since (6 months). The problem is a broken clutch tube. Attached is a picture of the problem when it first occurred……….which I thought was permanently fixed with a plug weld, but I guess I thought wrong because it’s broken again. The plug weld lasted 4 years, has anyone got any ideas on a permanent fix for this problem
rgalla9146 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,579 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None ![]() ![]() |
It can be done with a wide heater hose clamp.
Use a cut-off wheel to make two parallel slots about 3/4" apart one above the other on the side of the tunnel. Dress the ends or the slots with a small round file. Feed the end of the clamp into the lower slot then around the tube and out the upper slot. Feed the plain end of the clamp into the tightening slot and tighten away. It's tough on the fingers but it works.....with less fear than welding. Use a hole saw to make a 2" access hole in the top of the tunnel to allow access to install the clamp. |
Lo-Fi Version | Time is now: 27th June 2024 - 06:30 PM |
