Greenguy |
Member ![]() ![]() Group: Members Posts: 51 Joined: 29-December 06 From: Clovis, CA Member No.: 7,402 ![]() |
It’s good to see the board alive and well, I've keep track but haven’t posted in a long time. The reason that I’m back is that a reoccurring pain in the neck problem came back and the 914 has been parked since (6 months). The problem is a broken clutch tube. Attached is a picture of the problem when it first occurred……….which I thought was permanently fixed with a plug weld, but I guess I thought wrong because it’s broken again. The plug weld lasted 4 years, has anyone got any ideas on a permanent fix for this problem
dr914@autoatlanta.com |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,914 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None ![]() |
wow excellent picture, we reinstall the original bracket, weld the tube to the bracket and the bracket to the side of the tunnel, then go into the middle and weld the tube there and finally in the back burning out the factory braise and welding the tube to the firewall and have never had an additional problem (of course keep the cable well lubricated, the clevis and bushing in good condition, and the rear roller assembly clean and lubricated
It’s good to see the board alive and well, I've keep track but haven’t posted in a long time. The reason that I’m back is that a reoccurring pain in the neck problem came back and the 914 has been parked since (6 months). The problem is a broken clutch tube. Attached is a picture of the problem when it first occurred……….which I thought was permanently fixed with a plug weld, but I guess I thought wrong because it’s broken again. The plug weld lasted 4 years, has anyone got any ideas on a permanent fix for this problem ![]() |
Lo-Fi Version | Time is now: 27th June 2024 - 06:07 PM |
