JFG |
Senior Member ![]() ![]() ![]() Group: Members Posts: 686 Joined: 7-April 16 From: Wales Member No.: 19,869 Region Association: None ![]() |
Can someone advise where to fit the trim on the decklid grills?
I have replacement from 914 rubber but dont know where it fits. Or whether it fits the grills before fitting to the decklid or after. |
Mikey914 |
The rubber man ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,684 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None ![]() ![]() |
The welting has the J hook to go under the edge of the metal. The sides are a little more tricky as you will have to trim a little. On the side that is not secured down directly I use a dab of contact cement to secure. I also cut the notch from the bottom of the welting to relive the pin areas.
Hope this helps, And thanks for your business, Mark Attached image(s) ![]() |
Lo-Fi Version | Time is now: 25th June 2024 - 07:30 PM |
