Cylinder head temperature gauge install, where to get and how to install - should do this while motor is out and tin is off |
DRPHIL914 |
Mar 9 2018, 12:41 PM
Dr. Phil Group: Members Posts: 5,810 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
Being a 2.0 late car and having a tendency to run on the hot side and living in a hot climate, I think I should consider a cylinder head temp gauge. I have not seen one installed and would like to know how to proceed.
Now since putting the backdated HE on and the aux oil cooler oil temps have never been over 225/230 at the hardest running in the mountains on sustained up hill climbs. And I will finally have everything cleaned off properly and the tins all removed from the motor , under side cleaned up and have new warm air guides that were not on the car before, which should help as well. Either way seems like a good time to do this. advice on installation, wiring etc Thanks, Phil |
mgphoto |
Mar 9 2018, 02:21 PM
"If there is a mistake it will find me" Group: Members Posts: 1,365 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
The sensor end fits around the spark plug, like the sealing washer.
Cyl#3 is usually hottest. |
Lo-Fi Version | Time is now: 27th November 2024 - 01:50 AM |
