914GT |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,100 Joined: 11-October 04 From: Tucson Member No.: 2,923 Region Association: Southwest Region ![]() |
I'd like your comments about a project I'm working on. I have made a single integrated circuit design that replaces the old-technology internal VDO tach circuit. This is a more modern frequency-to-voltage converter (actually it's freq.-to-current) and it has several advantages over the original. Here are the key improvements:
I've made a prototype circuit board to finalize the design for bench-test, and I want to lay out the final board next. I planned to design it to replace the original circuit board. This does make it harder to get at the cylinder selection or calibration. It would be nice to keep the board inside the tach and not have something mounted on the back. Would most people be willing to remove the bezel to attempt doing this? That's the hardest part, using a small screwdriver to carefully pry the rim off. The rest is pretty easy, small screwdriver and soldering iron are needed. So, any interest in this? I'll build one for myself, but if this is something that would be popular it's possible for me to build up more as a kit. This would be for others like me who don't want an aftermarket tach and to keep it original-looking. Thanks for any suggestions. |
mightyohm |
Advanced Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,277 Joined: 16-January 03 From: Seattle, WA Member No.: 162 Region Association: Pacific Northwest ![]() ![]() |
Can you drill a couple holes in the back of the tach (with plugs to keep water out) and have adjustments for # cyls and calibration? That would be the ideal solution.
Lo-Fi Version | Time is now: 25th June 2024 - 12:12 AM |
