oakdalecurtis |
Oakdalecurtis ![]() ![]() ![]() Group: Members Posts: 1,329 Joined: 5-June 15 From: Oakdale, Ca Member No.: 18,802 Region Association: Central California ![]() ![]() |
How important is it for a tight fit, or not, of the SS heat exchangers at each end where they connect to the exhaust headers and the muffler?
eitnurg |
Country Member ![]() ![]() Group: Members Posts: 150 Joined: 31-December 02 From: Nairobi Member No.: 62 Region Association: None ![]() |
An update......the other one is broken too. This is the outside pipe on the driver's side, about 3 or 4" from the rear end of the jacket:
![]() And this is the inside pipe on the passenger's side, about midway: (the semi-circular arc visible is a complete break around the pipe: it's essentially 2 halves). ![]() Wall thickness appears to be a shade under 2mm, I don't know whether this is normal. But from the outside they appear undamaged: ![]() ![]() So they are both destined for the bin: fortunately I don't have to use them myself, but............what would be the first warning of failure while in use? Unconsciousness? Seems a bit drastic. |
Lo-Fi Version | Time is now: 24th June 2024 - 07:15 AM |
