914work |
Member ![]() ![]() Group: Members Posts: 291 Joined: 9-November 11 Member No.: 13,762 Region Association: None ![]() |
So I have one in the Werke shope that is a bad leak'er.
74 2.0L street car. Front mount cooler with the ubiquitous Mocal sandwich adapter which seems to be a significant (but not the entire) culprit. One of the issues that is probably contributing to the problem is the clearance of the oil filter. Due to the depth of the adapter the oil filter is low enough that the engine cross bar impacts the Oil filter. There is just enough clearance, but given the eng. bar is rubber mounted its without a doubt vibrating on the filter body. Anyone else deal with this & what was the solution. I checked the rubber mounts & they are in good shape. Different filter brand? Space out the Motor mounts off the case? Thanks Attached thumbnail(s) ![]() |
914work |
Great thanks for the replies.
Ill probably address it with more than one approach: * A little clearance on the bar isn't going to hurt anything * alternate filter One more Q: I am replacing the seal on the SP1T and notice there is no O-ring or seal on the sleeve adapter. Is there supposed to be one? |
Lo-Fi Version | Time is now: 22nd June 2024 - 09:46 PM |
