North Coast Jim |
Member ![]() ![]() Group: Members Posts: 326 Joined: 11-December 15 From: Northern Ohio Member No.: 19,450 Region Association: MidAtlantic Region ![]() ![]() |
Just bought this new aluminum trailer to haul my toys around. The setup for this trailer is 4 D ring points set 16' apart in the length and 4'8' in the width. How to strap down a 914 for safe hauling. Thanks all.
GaroldShaffer |
You bought another 914? ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 7,624 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None ![]() ![]() ![]() |
I have been towing 914s (and other Porsche cars) for well over 20 yrs. I always hook on the A-arm up front and then through the rear tires in back. If you are worried about marking up your rear rims then side a hand towel under the strap, it won't come out once the strap is tighten down.
I also have a small strap the goes around the trailing arm then hook a steel chain on it and hook up to a rear D -ring as a safetything "just in case I hit the brakes hard and the car moves forward (that has NEVER happen , but you never know). Nice trailer btw. (IMG:style_emoticons/default/beerchug.gif) Attached image(s) ![]() ![]() |
Lo-Fi Version | Time is now: 20th June 2024 - 05:34 AM |
