nditiz1 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,193 Joined: 26-May 15 From: Mount Airy, Maryland Member No.: 18,763 Region Association: MidAtlantic Region ![]() ![]() |
Ok so after finding out I did not have the new o ring and felt washer I ordered them from pelican.
I installed them and following the pelican article I noticed the bearing was not flush in my flywheel it was protruding as much as the thickness of the felt washer. I'm not sure if that was the PO intention. I hammered it flush with the face that goes towards the crank, was this correct? Before installing the new rear seal I wanted to ensure the endplay was correct. I put the 3 washers back on and hand tightened, lightly tightened with a wrench 3 flywheel bolts. I get anywhere from Thanks all. |
jcd914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California ![]() |
I always installed the flywheel with the three shims using the old lock plate, all the flywheel bolt and NO seal.
Then measure. If the end play is off and you have installed the seal you will have to pull the seal to change the shims. The seal probably won't survive being removed to replace a shim and you will have to replace it. Always install a new lockplate when your done. Jim |
Lo-Fi Version | Time is now: 25th June 2024 - 07:56 PM |
