100 - 115 - 110 - 110 Compression, In order 1234 for 1.8L |
qa1142 |
Nov 12 2004, 04:41 PM
Whiplash Group: Members Posts: 1,514 Joined: 1-June 04 From: Lake Zurich, Illinois Member No.: 2,140 |
Ok
likely not hot enough, ran it for 15-20 min. checked compression. Plugs are in the picture Left to right 1, 2, 3, 4 also. The 1974 had the lowest compression (right?). So is this low? Thanks gang Attached image(s) |
scruz914 |
Nov 12 2004, 05:12 PM
Senior Member Group: Members Posts: 815 Joined: 26-February 04 From: Santa Cruz, CA Member No.: 1,724 |
If it not your rings it could be a problem with your valves. When was the last adjustment? A valve may be a bit too tight and not completely closing. Much worse would be a chipped valve. I would check the valve adjustment and also retest with a little oil in the cylinder.
-Jeff |
Lo-Fi Version | Time is now: 26th September 2024 - 11:48 AM |
