Electrical frustration..., This is starting to piss me off. |
BMartin914 |
Nov 11 2004, 09:21 PM
||| Group: Members Posts: 1,408 Joined: 30-May 04 From: Oregon Member No.: 2,128 Region Association: Pacific Northwest |
So I have a recurring electrical problem in which my front marker lights, rear marker lights and rear tail light do not work.
I have traced down the wiring, see no problems. Cut open the harness and inspected as much as I can see (which is most of it) and still see NO problems (melting, arcing, etc.). Tonight I cleaned ALL the grounds (under relay tray, trans strap, fuse box, etc.). I then pulled all of the affected bulbs and planned to put them back in 1 by 1 until the fuse blew. Didn't get that far. As soon as I pulled the switch out the fuse blew. This leads me to believe that wires are arcing somewhere, but as indicated, I see no visible melting or arcing. Does anyone have any ideas? I am at the point where I am willing to re-wire the circuit to fix the problem. Anyone have any ideas before I re-wire this b**ch? Thanks. |
BMartin914 |
Nov 12 2004, 05:46 PM
Trying to get as much input as possible before I get back at it once I get home.
No work done prior to the problem appearing. Everything worked when I got the car. I just happened to notice about a month later that I had no left rear tail light, then noticed no marker lights. One other thing...the left rear light does or does not work in unison with the marker lights? I cannot remember what the schematic says. I am starting to think I may have two unrelated, possibly related problems, marker lights being the first, the left rear tail being the other. |
Lo-Fi Version | Time is now: 28th September 2024 - 02:42 PM |
