McMark |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,179 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None ![]() |
This question comes up every once in awhile, and did again in another thread. Rather than replying there I figured I'd make a new thread.
The 2270 number comes from 96mm pistons and 78.4 as the stroke. I'm pretty sure this 78.4 BS came from building motors for a racing class (probably under 2.3l) where people were trying to get as close to the limit as possible (more power). But the reality is that most 2270 engines are actually just off-the-shelf 78 stroke cranks. So 2258 is a better general reference term, I'd say it's more representative of what the engine is. But it doesn't roll off the tongue. I've moved to simply referring to them as 2.3l engines. If you REALLY want to be accurate, the '2270' that I'm assembling right now had a crank 78.26 and a 96mm bore. So really it's a 2266... (IMG:style_emoticons/default/rolleyes.gif) So call it a 2270, a 2258, or a 2.3l -- they're all the same idea and none are really all that accurate. |
Chris914n6 |
Jackstands are my life. ![]() ![]() ![]() ![]() Group: Members Posts: 3,350 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region ![]() |
I thought the 78mm was the largest that would spin without machining and something about smaller bore rods?
McMark |
I thought the 78mm was the largest that would spin without machining and something about smaller bore rods? Even a 78 can take a bit of clearancing in the case. 80 needs a bit more, but it's not precision work. Most of the engines 2.3 and beyond are using Chevy rods or Type 1 rods. 2.1 and below all use stock Type 4 rods. |
Lo-Fi Version | Time is now: 26th June 2024 - 03:17 AM |
