> Alternator question., Not Charging.
Olympic 914
post Mar 25 2018, 05:05 PM
Took the car out for a drive today, planning on going to dinner. everything is working as it should. getting on the PA turnpike and I had to accelerate briskly to get into traffic, and a moment later I noticed that the RED alternator light had come on. Pulled of at a wide spot to check the belt and wires and shut it off. Not checking the belt with it running. Belt good, plug tight, tapped the VR a couple times for good measure and started it back up. Light still on and now my Autometer AFR gauge just had bars. I know that is because it doesn't turn on until the voltage is +13v So not charging.
Now I am on a limited access highway with the next exit `12-15 miles away. Good thing had the battery fully charged on the tender before I left the house. So I made it to the next exit, turned around and headed back home for a total of 35 miles on battery only. Whew. But that shot dinner.....
Replace the VR with another I had that previously tested good. still no charging. checked the plug on the relay plate again. looks good.
I have not yet checked the wire connections at the alternator, possibly a wire vibrated loose during the brisk acceleration.
Now the question
I read to test the VR to short between D+ and DF and if the alternator is good voltage at the battery will go to alternator maximum of about 15-16V
So do I REMOVE the VR for this test? and jump between the D+ and DF at the relay plate.
OR
Leave the VR in place and short between those pins?
Olympic 914
post Apr 19 2018, 11:55 AM
There is also this.
I performed the tests below the red line.
There are four connections to the alternator itself. D+, DF,D-, and B+. If you look at the Haynes book, what is not readily apparent, but is true nevertheless, is that the set of diodes that connect to the D+ terminal are a duplicate set (except for lower curent rating) to the ones for the B+ terminal, which is the actual high current output of the alternator. The D+ terminal is therefore a duplicate output terminal of the alternator, with less current capability. The lower set of diodes on current track 80 is common to both the D+ and B+ functions, and forms the ground return for both the B+ and D+ outputs. The DF or "Dynamo Field" terminal connects to the ungrounded end of the alternator field winding, and is an input to the alternator. The current supplied to the DF terminal determines the strength of the magnetic field that penetrates the output windings, and thus controls the alternator's output. The D- terminal is connected to the alternator frame, and is the ground return for the voltage regulator. The other end of the field winding is also connected to ground at this point.
The Bosch alternator is incapable of self-excitation, or "boot-strapping" itself to an operating condition. Older DC generators and some U.S. alternators have residual magnetism retained in the core, or some other scheme to get enough field current to get themselves up and running. The Bosch alternator uses a different scheme. The charge warning lamp is connected between the ignition switch and the D+ terminal. When the car is first started, there is no output from the alternator at either the B+ or D+ terminals. The voltage regulator, sensing no output, is attempting to command maximum field current... it effectively shorts the D+ and DF terminals together. This places the D+ terminal close to ground potential, because the resistance of the field winding is not large. This means that there is +12 volts on one side of the charge warning lamp, and the other side of the lamp is grounded through the alternator field winding. Current thus flows through the lamp, lighting it. This same current, however, also flows through the alternator field winding, producing a magnetic field. This magnetic field is what the alternator needs to start up, and if everything is working correctly, that's exactly what happens. The alternator now begins to develop identical voltages at the D+ and B+ terminals. The D+ terminal is connected to one end of the charge warning lamp, while the other end of the lamp is connected to the battery via the ignition switch. Since the B+ terminal is hard-wired to the battery, and since both the D+ and B+ diodes are fed from the same set of windings in the alternator, no voltage difference can exist between these two points. The warning lamp goes out.
The voltage regulator "watches" the voltage at the D+ point, which should be the same as that applied to the battery. It now changes the short between the D+ and DF terminals into a variable resistance. This effectively controls the field current (whose source is now the output from the D+ terminal, and not the charge warning lamp) and thus regulates the output voltage of the alternator.
Fault conditions: When something happens to the charging system that causes it's output to be insufficient, the result is almost always a net voltage difference across the charge warning lamp, causing it to light. For example: Suppose an output (B+) diode opens. The efficiency of the main output is now considerably reduced. The voltage regulator does not know this, however, because it is looking at the D+ point. So, the B+ output is now lower than the D+ point and the warning lamp lights. Let's say that one of the D+ diodes failed: The D+ output is now reduced considerably. This means that the voltage regulator will have difficulty in maintaining sufficient field current for normal output. The field regulating resistance is low or short (between D+ and DF terminals) and the resulting load on the crippled D+ system drops it's voltage well below the battery voltage. Therefore, there is a net voltage difference across the charge warning lamp and it lights.
The bottom line is that in order for your light to light, you must have a net imbalance in the outputs of the D+ and B+ sections of the alternator (or between the D+ output and the battery voltage, which amounts to the same thing).
________________________________________________________________________________
To trouble-shoot the problem, you need to check the various sections independently. Thus the first check: Connect +12 volts from the battery to the DF terminal on the relay board. This is the maximum field current situation, and should result in maximum output of the alternator. Note that this checks the B+ diodes, the alternator windings, and the common diodes. It does NOT check the D+ diodes.
To check the D+ portion of the system, it is necessary to find out if the D+ output can produce enough current to drive the alternator to full output. To do this, short the D+ and DF terminals on the relay board. This will provide the maximum field current to the alternator that the alternator ITSELF can supply (not the battery, as in the earlier check) and so checks the remainder of the circuitry. If this test puts the light out, then the alternator is good, and the trouble is elsewhere. If it doesn't, then the alternator is almost certainly bad, with one other possibility:
In the Bosch system, the size of the charge warning lamp bulb is critical. Too low a wattage bulb will not supply enough field current for "bootstrap" operation to be reliable. The Bosch book that I have states that the lamps must be at least 2 watts for 12 volt systems. If you have replaced your charge warning lamp recently, then too small a lamp may be your culprit.
Olympic 914   Alternator question.   Mar 25 2018, 05:05 PM
Spoke   Took the car out for a drive today, planning on g...   Mar 26 2018, 07:21 AM
Olympic 914   Yes, disconnect only the VR. Jump the D+ and DF...   Mar 26 2018, 08:37 AM
falcor75   Ground cable between gearbox and chassi?   Mar 26 2018, 08:47 AM
Olympic 914   Ground cable between gearbox and chassi? New, C...   Mar 26 2018, 08:55 AM
Mikey914   Well if all works well great. I'd try driving ...   Mar 26 2018, 09:40 AM
Olympic 914   Well if all works well great. I'd try driving...   Mar 26 2018, 09:50 AM
Olympic 914   So this alternator problem continues to vex me. ...   Apr 18 2018, 07:20 PM
malcolm2   Next step will be to pull the alternator and pro...   Apr 19 2018, 08:04 AM
McMark   Dying relay board?   Apr 19 2018, 05:30 AM
Olympic 914   Dying relay board? I did hook up another relay ...   Apr 19 2018, 06:20 AM
malcolm2   I have had some ALT probs too. Spoke must keep th...   Apr 19 2018, 07:08 AM
McMark   I think malcolm2 is right -- and I don't think...   Apr 19 2018, 07:34 AM
Tdskip   I think malcolm2 is right -- and I don't thin...   Mar 28 2019, 06:13 AM
malcolm2   I am bored today. Hey Spoke, how is this???   Apr 19 2018, 09:13 AM
Olympic 914   There is also this. I performed the tests belo...   Apr 19 2018, 11:55 AM
McMark   Damn!!! That’s a fantastic post. :dr...   Apr 19 2018, 04:09 PM
bulitt   Yes, you must excite the Alternator to wake it up....   Apr 19 2018, 04:58 PM
Mikey914   Yes, you must excite the Alternator to wake it up...   Apr 20 2018, 10:20 AM
Edward Blume   I had my stock Bosch alternator professionally reb...   Apr 19 2018, 05:58 PM
jcd914   I don't recall the years but there was a TSB f...   Apr 20 2018, 10:36 AM
Olympic 914   On Thursday took the alternator to the local FLAPS...   Apr 22 2018, 11:52 AM
Spoke   :beer2:   Apr 22 2018, 12:07 PM
GregAmy   That post #15 is a gem... Camping onto this one f...   May 13 2018, 01:22 PM
Spoke   Does everyone else's GEN light come on with k...   May 13 2018, 02:20 PM
GregAmy   Yes, the light is on with key on and engine not ru...   May 13 2018, 03:45 PM
Spoke   Yes, the light is on with key on and engine not r...   May 13 2018, 05:30 PM
GregAmy   = About the measurements, here's what I think...   May 14 2018, 05:05 AM
GregAmy   = About the measurements, here's what I think...   May 14 2018, 03:55 PM
GregAmy   Camping onto this one for a slightly different pr...   Mar 25 2019, 07:58 PM
worn   Camping onto this one for a slightly different p...   Mar 25 2019, 08:13 PM
GregAmy   Maximum alternator output is triggered when you b...   Mar 26 2019, 05:06 AM
DRPHIL914   Camping onto this one for a slightly different p...   Mar 27 2019, 10:33 AM
VaccaRabite   Greg, Glad you solved it. My issue was the lacke...   Mar 27 2019, 07:39 PM
euro911   I have several 'unknown condition' units I...   May 14 2018, 02:27 AM
GregAmy   Aaaaand a new voltage regulator... ...didn't ...   May 14 2018, 04:32 PM
Spoke   Bummer. I didn't think the VR was at fault but...   May 15 2018, 07:04 PM
GregAmy   Yep. All grounds and battery cables replaced by me...   May 16 2018, 06:42 AM
dangrouche   Yep. All grounds and battery cables replaced by m...   May 17 2018, 11:27 AM
GregAmy   the pigtail at the alternator end needs the altern...   May 18 2018, 08:07 AM
dangrouche   https://www.aspwholesale.com/index.php here is a ...   May 18 2018, 11:24 AM
Gatornapper   Ok, friends - this thread has been very helpful, b...   Aug 31 2019, 07:07 PM
Spoke   Try these measurements with engine running; lights...   Aug 31 2019, 08:14 PM
Gatornapper   Only work on car had nothing to do with electrical...   Sep 1 2019, 07:20 AM
Spoke   Should I read these voltages at the VR pins as we...   Sep 1 2019, 07:48 AM
Gatornapper   I have quite a bit of experience with circuit boar...   Sep 1 2019, 11:36 AM
Gatornapper   Spoke - Ran tests tonight after 1 hour drive, so ...   Sep 3 2019, 06:26 PM
Spoke   Spoke - Ran tests tonight after 1 hour drive, so...   Sep 3 2019, 07:34 PM
Gatornapper   Spoke - yes, GEN light is OFF until I turn on head...   Sep 3 2019, 08:08 PM
914Sixer   Do you have a spare relay board to swap out?   Sep 1 2019, 07:41 AM
904svo   Just a WAG, measure the voltage between the altern...   Sep 3 2019, 07:28 PM
Gatornapper   Thanks for the idea - I'll do that. But previ...   Sep 3 2019, 07:37 PM
Gatornapper   Re: VR not working. Both VR's I have get ver...   Sep 4 2019, 06:21 AM
Olympic 914   Re: VR not working. Both VR's I have get ve...   Sep 4 2019, 06:45 AM
Gatornapper   Thanks - would like to get one.... Checked BERU...   Sep 4 2019, 09:42 AM
Spoke   Re: VR not working. Both VR's I have get ve...   Sep 4 2019, 07:06 PM
euro911   Typically can't purchase products from compani...   Sep 4 2019, 11:43 AM
Gatornapper   Thanks Mark. Typically can't purchase produc...   Sep 4 2019, 05:21 PM
Gatornapper   Ok, test results: Relay board not the problem.......   Sep 4 2019, 05:28 PM
Spoke   Ok, test results: Relay board not the problem......   Sep 4 2019, 07:24 PM
VaccaRabite   Keep in mind that without the alternator working,...   Sep 5 2019, 07:58 AM
Gatornapper   Zach - First running one to the shroud. Then ch...   Sep 5 2019, 11:03 AM
jcd914   Maybe I missed in the thread but did you check vol...   Sep 4 2019, 05:53 PM
Gatornapper   Jim - will check tomorrow, but checked all other p...   Sep 4 2019, 08:09 PM
Gatornapper   Spoke - Will run all suggested tests tomorrow - ...   Sep 4 2019, 08:23 PM
Spoke   So when I check D- to chassis that's with the...   Sep 5 2019, 04:15 AM
Gatornapper   Dumb question: if the VR is in place, where do I ...   Sep 5 2019, 10:59 AM
Spoke   Dumb question: if the VR is in place, where do I...   Sep 5 2019, 03:58 PM
Spoke   This diagram shows which signals are which. In th...   Sep 5 2019, 04:02 PM
Gatornapper   I should have told you all I don't have regula...   Sep 5 2019, 04:54 PM
Spoke   It makes me wonder if the VR is not starting becau...   Sep 5 2019, 05:41 PM
Gatornapper   Ok, I can do that, but then I need someone else at...   Sep 5 2019, 06:12 PM
Gatornapper   I have another idea: I'll bring a 1 amp fused...   Sep 5 2019, 06:18 PM
Spoke   I have another idea: I'll bring a 1 amp fuse...   Sep 5 2019, 06:41 PM
Gatornapper   Spoke - Ok, let's assume that jumping 12+ to ...   Sep 5 2019, 07:05 PM
Spoke   Spoke - Ok, let's assume that jumping 12+ to...   Sep 5 2019, 07:29 PM
Spoke   I have another idea: I'll bring a 1 amp fuse...   Sep 6 2019, 04:47 PM
Gatornapper   I have another idea: I'll bring a 1 amp fus...   Sep 7 2019, 05:46 AM
Gatornapper   Spoke - D- to engine or chassis with engine runni...   Sep 5 2019, 06:05 PM
914Sixer   Adding information from owners manual. Please rea...   Sep 6 2019, 02:54 PM
Gatornapper   Mark - yes, I know this - so I have 3 bad VR's...   Sep 6 2019, 03:34 PM
914Sixer   I would say the Bosch ones are ok. Is the alterna...   Sep 6 2019, 03:54 PM
Gatornapper   I would say yes. But remember, it puts out full v...   Sep 7 2019, 05:32 AM
Gatornapper   Post I just made on Pelican's forum: Greg - ...   Sep 7 2019, 07:15 PM
ClayPerrine   You can't use just any light for the alternato...   Sep 7 2019, 07:20 PM
Gatornapper   Clay - The 2nd VR I tried is NOS I got from a rel...   Sep 7 2019, 07:53 PM
Gatornapper   Clay - The [b]strong implication of this statemen...   Sep 8 2019, 05:54 AM
Spoke   Did you do the test with the 1156 bulb across the ...   Sep 8 2019, 09:41 AM
Gatornapper   Yes. Nothing happened. Did not energize the arma...   Sep 8 2019, 11:24 AM
Spoke   Yes. Nothing happened. Did not energize the arm...   Sep 8 2019, 04:45 PM
Gatornapper   [quote name='Gatornapper' post='2745248' date='Se...   Sep 8 2019, 06:17 PM
euro911   At this point I'm suspecting one of the altern...   Sep 8 2019, 07:25 PM
Gatornapper   Mark - Totally understand - but if one of the di...   Sep 8 2019, 07:33 PM
Spoke   At this point I'm suspecting one of the alter...   Sep 8 2019, 08:58 PM
VaccaRabite   At this point I'm suspecting one of the alte...   Sep 9 2019, 11:06 AM
Gatornapper   Memories guys? Jerry & Zack - Long ago I jump...   Sep 9 2019, 07:26 PM
Spoke   ...I jumped D+ & DF and did get full 17v at t...   Sep 9 2019, 10:50 PM
Gatornapper   Ok, will do today. One additional bit of info: G...   Sep 10 2019, 07:21 AM
Spoke   Here's a way to do a quick test on the VR. I j...   Sep 9 2019, 11:52 PM
Spoke   Part 2 of the VR test is to check the D+ and DF vo...   Sep 10 2019, 12:04 AM
- Lo-Fi Version Time is now: 21st September 2026 - 10:56 PM
