BMartin914 |
||| ![]() ![]() ![]() Group: Members Posts: 1,408 Joined: 30-May 04 From: Oregon Member No.: 2,128 Region Association: Pacific Northwest ![]() |
So I have a recurring electrical problem in which my front marker lights, rear marker lights and rear tail light do not work.
I have traced down the wiring, see no problems. Cut open the harness and inspected as much as I can see (which is most of it) and still see NO problems (melting, arcing, etc.). Tonight I cleaned ALL the grounds (under relay tray, trans strap, fuse box, etc.). I then pulled all of the affected bulbs and planned to put them back in 1 by 1 until the fuse blew. Didn't get that far. As soon as I pulled the switch out the fuse blew. This leads me to believe that wires are arcing somewhere, but as indicated, I see no visible melting or arcing. Does anyone have any ideas? I am at the point where I am willing to re-wire the circuit to fix the problem. Anyone have any ideas before I re-wire this b**ch? Thanks. |
BMartin914 |
So I get it back together, everything buttoned up and go to check for functionality. Alright! Lights at all 4 corners and signals, but the left ones are now brighter than the right. I figure I have the wires crossed so i switch them (w/out the tire off) and lose my signal. I'm hungry, so I'm calling it a night.
Back at it in the morning. Any suggestions? I am going to pull the wheel off tomorrow and get the diagram out to double check everything. |
Lo-Fi Version | Time is now: 28th June 2024 - 12:49 PM |
