Lucky9146 |
Always Wanted A Bigger Go Cart ![]() ![]() ![]() Group: Members Posts: 1,676 Joined: 22-September 14 From: Poway California Member No.: 17,942 Region Association: Southern California ![]() ![]() |
This sway bar here
![]() My driver side looks like this ![]() And my passenger side looks like this ![]() Seems to be some room on either side of the bushing cup totaling abut 1.75 in. for the bar to wander off to one side as mine did. (IMG:style_emoticons/default/confused24.gif) You can weigh in here on go to my thread page 31 http://www.914world.com/bbs2/index.php?showtopic=261197 Thanks! (IMG:style_emoticons/default/white914.jpg) |
jcd914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,090 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California ![]() |
I have dealt with this in a few ways.
First push the bushing all the way in to the bush cup mounted to the inner fended, they should only stick a short distance. Then loosen the arms on the bar and work them in as far as they will go. The arms clamp on the square end of the bar and can move around if loose or may not have been install pushed on to the bar as far as possible. Now you will know how much gap you have to deal with. I have had some where there was very little gap and the bar could only move back and forth a few mm. If you have enough gap your bar will move side to side much, there are different ways to fill the gap. However you deal with the gap you want to end up with the arms equally spaced on each side of the car in order to keep the geometry of the swaybar arms, drop links and A-arms the same. The hose clamp the some kits come with is functional but I don't like it. Clamp on collars work much better but you then might have metal rubbing against metal depending on where you install them. I have always put them on the outside, between the swaybar arm and the bushing. It means you don't have to remove the fuel tank if you want to take the bar out or if a collar worked loose and needs to be tightened. I have had spacers made of plastic bushing material (turcite), basically a pair of large plastic washers that fit over the bar and go between the arm and the bushing end or the bushing cup. I have had wider bushing made up that have a step so the push into the bushing cup and stop against the outer edge and have a larger surface for the swaybar arm to rub against. I have also (in a pinch) taken a PVC pipe fitting that fit over the bar and cut it into spacers to fit between the sway bar arm and the bushing to fill the gap. Note: I did not do this on a customers car, not a real professional solution but it worked. You just want the bar centered and set up with very little play to move side to side. Jim |
Lucky9146 |
I have dealt with this in a few ways. First push the bushing all the way in to the bush cup mounted to the inner fended, they should only stick a short distance. Then loosen the arms on the bar and work them in as far as they will go. The arms clamp on the square end of the bar and can move around if loose or may not have been install pushed on to the bar as far as possible. Now you will know how much gap you have to deal with. I have had some where there was very little gap and the bar could only move back and forth a few mm. If you have enough gap your bar will move side to side much, there are different ways to fill the gap. However you deal with the gap you want to end up with the arms equally spaced on each side of the car in order to keep the geometry of the swaybar arms, drop links and A-arms the same. The hose clamp the some kits come with is functional but I don't like it. Clamp on collars work much better but you then might have metal rubbing against metal depending on where you install them. I have always put them on the outside, between the swaybar arm and the bushing. It means you don't have to remove the fuel tank if you want to take the bar out or if a collar worked loose and needs to be tightened. I have had spacers made of plastic bushing material (turcite), basically a pair of large plastic washers that fit over the bar and go between the arm and the bushing end or the bushing cup. I have had wider bushing made up that have a step so the push into the bushing cup and stop against the outer edge and have a larger surface for the swaybar arm to rub against. I have also (in a pinch) taken a PVC pipe fitting that fit over the bar and cut it into spacers to fit between the sway bar arm and the bushing to fill the gap. Note: I did not do this on a customers car, not a real professional solution but it worked. You just want the bar centered and set up with very little play to move side to side. Jim Jim Thanks this was very helpful and I appreciate the picture too. This is the kind of stuff I was was looking for! (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/white914.jpg) |
Lo-Fi Version | Time is now: 20th April 2025 - 06:51 AM |
