DrifterJay |
I break stuff... ![]() ![]() ![]() Group: Members Posts: 1,034 Joined: 25-May 03 From: Oceanside, California Member No.: 737 Region Association: None ![]() |
ok...brain fart here....what goes where on the coil....simple as that. (IMG:style_emoticons/default/biggrin.gif)
-Jared |
SLITS |
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None ![]() ![]() |
1.) If you remove the dizzy cap and have the power hooked up to the coil with the dizzy points closed, when you push them open with a screwdriver, you should see a spark.
2.) If the power is hooked to the coil and the points are closed, the coil should get warm and eventually hot and explode. 3.) The points must open and close for the coil to work. |
Lo-Fi Version | Time is now: 28th June 2024 - 05:15 AM |
