DrifterJay |
I break stuff... ![]() ![]() ![]() Group: Members Posts: 1,034 Joined: 25-May 03 From: Oceanside, California Member No.: 737 Region Association: None ![]() |
ok...brain fart here....what goes where on the coil....simple as that. (IMG:style_emoticons/default/biggrin.gif)
-Jared |
hargray2 |
fuh-q ![]() ![]() Group: Members Posts: 302 Joined: 12-December 03 From: hardeeville,sc Member No.: 1,432 ![]() |
How do you know you don't have spark? Do you have a plug out looking for a spark?
Did you remember to ground the threads on the plug when looking for spark? If you have 12v on the coil, check your gap on the points. -------------------------------------------------------------------------------------------------------------- You can check your coil like this. Every time you touch the negative coil wire to ground, you should get a spark. Make sure the threads on the plug has a good ground when you do this. Attached image(s) ![]() |
Lo-Fi Version | Time is now: 28th June 2024 - 04:59 AM |
