loco914 |
Thy wheels have left the rail... ![]() Group: Members Posts: 45 Joined: 1-April 10 From: Amarillo, TX Member No.: 11,542 Region Association: None ![]() |
IronHillRestorations |
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,735 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None ![]() ![]() |
You are going to run much cooler with all the motor smeg cleaned off.
If you pull the flywheel make sure you use a Sabo seal. Don't score the seal bore or you can make an oil leak. You want a full flywheel package and replace the pilot bearing and felt washer too. The plate under the flywheel bolts is a one and done, so make sure you get one of those too. |
Lo-Fi Version | Time is now: 27th June 2024 - 06:58 PM |
