D-Jet Distributor Condenser Work Around, New Parts From Bosch Too Short. |
914Sixer |
Apr 26 2018, 05:13 PM
914 Guru Group: Members Posts: 8,920 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
When I was gathering parts to rebuild the two distributors I have, I found the new Bosch condensers with the correct numbers were to short. I did find some NOS ones that were long enough. I knew that there must be a better solution, besides I did not like the way the wire came all the way across the distributor. I kept looking at Bosch condensers until this one popped up. It is designed for the 912 distributor. There are two versions one with the square hole and the round hole. Only the round hole will work. Since then I have found a couple more versions that will work also. You can make a custom fitted wire from the distributor to the coil. I like the cleaner look. Pictures show NOS factory setup first then the revised version.
Attached image(s) |
914Sixer |
Apr 26 2018, 06:44 PM
Condenser is moved from being mounted over on the vacuum canister to right at the plug where it needs to be.
Lo-Fi Version | Time is now: 26th June 2024 - 02:21 AM |
