qa1142 |
Whiplash ![]() ![]() ![]() Group: Members Posts: 1,514 Joined: 1-June 04 From: Lake Zurich, Illinois Member No.: 2,140 ![]() |
So fuel pump is mounted by steering rack and I need to get the last ~ 5 gallons out.
If I drop the pump and disconect the outlet hose, till it dump on me? or will I have time to hook up a hose? I want to just turn on the pump and pump it into my 5 gal gas can(s). thoughts. This is a single inlet, single outlet pump. I could also tap in back by engine, fuel filter, fuel injector loop, fuel presure tap, etc. |
SLITS |
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None ![]() ![]() |
So, using vise grips, pinch the outlet line of the tank closed, remove the pump and let it drain into a container.
Otherwise, connect power to the pump and put the pressure hose in the engine compartment in a container and pump away. The problem here is possibility of sucking the crap that is in the bottom of the tank when it starts to run dry. |
Lo-Fi Version | Time is now: 28th June 2024 - 01:17 PM |
