98101 |
Michael in Seattle ![]() ![]() Group: Members Posts: 373 Joined: 7-October 17 From: Seattle, WA Member No.: 21,495 Region Association: Pacific Northwest ![]() |
I bought this car a couple months ago, and wrestling with problems that I expected, and some I didn't expect.
Dyno shop got a noticeable performance improvement by reaming out the main jets. We played with the timing curve a little bit also. Unfortunately the clutch is contaminated or something and sometimes interfered with torque readings. Now that I've read more about 2366 longevity, I'm not sure I'd opt for it. It sounds great and pulls harder than I'm used to in a 914 though. ![]() ![]() |
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
Odd that it says it's a standard base circle cam, shouldn't clear one lobe with an 80mm crank.
Chris is right that's a conservative grind for the engine size. |
98101 |
Odd that it says it's a standard base circle cam, shouldn't clear one lobe with an 80mm crank. Chris is right that's a conservative grind for the engine size. No idea why PO went to all that trouble just to use that cam. FWIW, he wasn’t very active on this forum. I’m not feeling ready to split the case on a motor that was just built last year. Is there any point in bigger exhaust (background: currently has 1 5/8” European Racing Headers)? Secondary consideration: Tangerine’s exhaust appeals to me because I’ve realized I’m old enough to appreciate a working heater and defogger. |
Lo-Fi Version | Time is now: 25th June 2024 - 01:12 AM |
