Flasher relay issue, Electrical issue with relay |
gfrewin |
May 2 2018, 07:04 AM
Newbie Group: Members Posts: 23 Joined: 2-May 18 From: Burlington, Ontario Member No.: 22,091 Region Association: Canada |
Hello,
I'm a new 914 owner and also new to this forum and hoping someone can help steer me in the right direction. Over the winter I restored the dash on my 1972 914-4 and removed the gauges. Before I put the gauges back in I installed a retrosound radio and when I tested it I also tested the lights, 4-way flashers and turn signals and all was fine. When I put it all back together a couple of days ago and went to start it, the relay was active when I turn the key to the on position. Not activating the exterior lights but the heat warning lights flash in the fuel gauge. When I pull the hazard switch on, the relay stops. It also stops when the car is actually running. When I try to use the turn signals it blows a fuse. I've triple checked the wiring of the gauges and all looks correct. I'm considering replacing the relay but I wanted to see if anyone had any insight before I start throwing parts at the problem. Any help would be greatly appreciated. Thanks, Gregg. |
Mike Bellis |
May 2 2018, 07:40 AM
Resident Electrician Group: Members Posts: 8,346 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
Most likely the radio installation is the culprit. The 914 does not have an accessory wire so most radios are wired hot all the time. If not, you risk burning your points or electronic ignition.
gfrewin |
May 2 2018, 07:45 AM
Most likely the radio installation is the culprit. The 914 does not have an accessory wire so most radios are wired hot all the time. If not, you risk burning your points or electronic ignition. Thanks Mike. the PO had a radio in the car and I followed his wiring for the new one. I also did disconnect the radio harness during my troubleshooting and it was still doing it. |
Lo-Fi Version | Time is now: 22nd September 2024 - 12:08 PM |
