Flasher relay issue, Electrical issue with relay |
gfrewin |
May 2 2018, 07:04 AM
Newbie Group: Members Posts: 23 Joined: 2-May 18 From: Burlington, Ontario Member No.: 22,091 Region Association: Canada |
Hello,
I'm a new 914 owner and also new to this forum and hoping someone can help steer me in the right direction. Over the winter I restored the dash on my 1972 914-4 and removed the gauges. Before I put the gauges back in I installed a retrosound radio and when I tested it I also tested the lights, 4-way flashers and turn signals and all was fine. When I put it all back together a couple of days ago and went to start it, the relay was active when I turn the key to the on position. Not activating the exterior lights but the heat warning lights flash in the fuel gauge. When I pull the hazard switch on, the relay stops. It also stops when the car is actually running. When I try to use the turn signals it blows a fuse. I've triple checked the wiring of the gauges and all looks correct. I'm considering replacing the relay but I wanted to see if anyone had any insight before I start throwing parts at the problem. Any help would be greatly appreciated. Thanks, Gregg. |
914Toy |
May 2 2018, 08:43 AM
Senior Member Group: Members Posts: 721 Joined: 12-November 17 From: Laguna beach Member No.: 21,596 Region Association: Southern California |
I have similar problems - trouble shooting took me to turn signal/emergency flasher relay switch. Switch board is corroded see pic. Have a new one on order from Bruce at Pelican.
Attached image(s) |
malcolm2 |
May 3 2018, 07:57 AM
Advanced Member Group: Members Posts: 2,747 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
Have a new one on order from Bruce at Pelican. You should read thru my post about my flasher relay issues. Bought a Wheryle (sp?) brand and it worked but not correctly. I thought I was doing good buying a German part. I returned mine and bought one from SPOKE. MY POST The aftermarket relays are so bad, and so widely used, people don't even realize that the brake light is supposed to flash and click when the hand brake is pulled. Or that silver dot tachs with r & L indicator lights are supposed to blink in one direction. |
Lo-Fi Version | Time is now: 20th June 2024 - 11:15 PM |
