Ross |
Member ![]() ![]() Group: Members Posts: 90 Joined: 17-August 16 From: Charlotte, NC Member No.: 20,304 Region Association: South East States ![]() |
Hi Everyone,
RE: 1972 914 1.7L Just wanted to get you all's thoughts on an issue I'm having. Here's my observations: 1. When cruising (not accelerating or decelerating) the car skips and almost feels like it is cutting off. It doesn't matter the speed. 2. It accelerates fine and when decelerating it is fine. 3. I replaced the ignition wires, plugs and coil last weekend. No improvement. 4. I had electronic ignition put in about a year and a half ago. Not sure if that could be the culprit. Any help/thoughts would be much appreciated. Thanks |
Rand |
Cross Member ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,409 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None ![]() |
Don't swap to carbs. Do check the TPS.
stevend914 |
Member ![]() ![]() Group: Members Posts: 376 Joined: 13-December 16 From: Saint Louis Member No.: 20,670 Region Association: Upper MidWest ![]() ![]() |
Don't swap to carbs. Do check the TPS. (IMG:style_emoticons/default/agree.gif) I had the same problem. Replaced the TPS and problem solved. |
Lo-Fi Version | Time is now: 20th June 2024 - 06:06 AM |
