tomh |
Member ![]() ![]() Group: Members Posts: 322 Joined: 28-February 10 From: san jose Member No.: 11,412 Region Association: None ![]() |
Stock 74 2.0 with FI,out driving this morning noticed the pedal a little sticky got back home a took a look and found the shaft and spring not snapping back sharply.
After snapping it back and forth 5-6 times it worked itself back to working. It is pretty dusty and it just needs to be cleaned. My question before I start spraying a bunch of stuff down there what is the best cleaner for the throttle body. Thanks all |
Bartlett 914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,216 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest ![]() |
Stock 74 2.0 with FI,out driving this morning noticed the pedal a little sticky got back home a took a look and found the shaft and spring not snapping back sharply. After snapping it back and forth 5-6 times it worked itself back to working. It is pretty dusty and it just needs to be cleaned. My question before I start spraying a bunch of stuff down there what is the best cleaner for the throttle body. Thanks all A little WD40 may help. these bushings often wear out and cause a sticky throttle plate, I offer a repair service for this. Throttle body repaie service |
Lo-Fi Version | Time is now: 26th June 2024 - 02:14 AM |
