Throttle linkage sticky |
tomh |
May 13 2018, 03:17 PM
Member Group: Members Posts: 322 Joined: 28-February 10 From: san jose Member No.: 11,412 Region Association: None |
Stock 74 2.0 with FI,out driving this morning noticed the pedal a little sticky got back home a took a look and found the shaft and spring not snapping back sharply.
After snapping it back and forth 5-6 times it worked itself back to working. It is pretty dusty and it just needs to be cleaned. My question before I start spraying a bunch of stuff down there what is the best cleaner for the throttle body. Thanks all |
tomh |
May 13 2018, 08:55 PM
Sounds good is their a instruction clip on how to repair using the kit.
BeatNavy |
May 14 2018, 04:37 AM
Certified Professional Scapegoat Group: Members Posts: 2,926 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region |
Sounds good is their a instruction clip on how to repair using the kit. There are at least several points where the throttle can stick and cause driving / idling issues. One is the butterfly plate shaft in the throttle body. That's what Mark (above) repairs / rebuilds. It's a service, not a "kit." You send him your throttle body and he'll ream it out and put a bushing in to make sure the plate moves and closes freely. He also cleans it up nicely. Other potential problem points are: The return spring(s) at the throttle body (missing, damaged, worn-out). The throttle cable. It could be kinked, catching, or disintegrating somewhere along the route up to the pedal cluster. And then the pedal cluster itself. The bushings could be worn out and causing things to stick at that point. Bruce (bdstone914) services those. I replaced ALL of those things - the pedal cluster most recently - and now I do have great throttle movement / response. |
rmital |
May 14 2018, 06:54 AM
Northeast optimist Group: Members Posts: 1,948 Joined: 12-December 05 From: Park Ridge, NJ Member No.: 5,268 |
.....I replaced ALL of those things - the pedal cluster most recently - and now I do have great throttle movement / response. Oddball: "I only ride 'em, I don't know what makes 'em work" sorry, been looking at your avatar for too long, had to make an obscure comment...at least for those not familiar with Kelly's Hero's |
Lo-Fi Version | Time is now: 26th June 2024 - 02:11 AM |
