sdoolin |
Member ![]() ![]() Group: Members Posts: 366 Joined: 1-May 14 From: LouKY Member No.: 17,299 Region Association: None ![]() |
I have read as much as I can stand on measuring deck height in preparation for doing just that as part of my 2056 build (different thread). While I am comfortable with the process once set-up, I can't tell from all of my reading if I should begin with a shim/gasket between jug and case, or if I should begin naked (no shim/gasket)?
I would think that I'd want to use the 4 metal gaskets (VR P/N 17-00121-01) that came with the gasket set as a crushable seal to keep oil in the engine, and so as-such would think I'd begin my deck height and CR measurements with these in place. However, I have seen many suggestions to do the set-up without "shims". Do we consider the "shims" different than the "gaskets"? As always all help appreciated. |
914werke |
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,166 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest ![]() ![]() |
I recently tore down a engine that was found set up w/o base gaskets/shims on one bank and a single (.008 compressed) shim on the other bank.
The bare bank showed clear signs of marring of the registers that wasn't present on the opposite bank. Both banks probably had a equal amount of oil leakage / grime present. Shouldnt some shim always be used between jug & register? |
Lo-Fi Version | Time is now: 20th June 2024 - 11:46 PM |
