Deck Height Q, To shim/gasket or not to? |
sdoolin |
Mar 28 2016, 11:05 AM
Member Group: Members Posts: 382 Joined: 1-May 14 From: LouKY Member No.: 17,299 Region Association: None |
I have read as much as I can stand on measuring deck height in preparation for doing just that as part of my 2056 build (different thread). While I am comfortable with the process once set-up, I can't tell from all of my reading if I should begin with a shim/gasket between jug and case, or if I should begin naked (no shim/gasket)?
I would think that I'd want to use the 4 metal gaskets (VR P/N 17-00121-01) that came with the gasket set as a crushable seal to keep oil in the engine, and so as-such would think I'd begin my deck height and CR measurements with these in place. However, I have seen many suggestions to do the set-up without "shims". Do we consider the "shims" different than the "gaskets"? As always all help appreciated. |
914werke |
May 24 2018, 09:58 PM
"I got blisters on me fingers" Group: Members Posts: 10,535 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Base shims. No paper gaskets present, Cast steel cylinders directly on aluminum case/register. The other bank had only a single shim
I didnt mention bore but in this case it is an OE 94mm 2.0L that from appearances had never been messed with. |
Lo-Fi Version | Time is now: 22nd September 2024 - 12:12 PM |
