Head Studs |
Head Studs |
SzoylentGreen |
May 25 2018, 08:42 AM
Newbie Group: Members Posts: 4 Joined: 23-March 18 From: Bloomington IN Member No.: 21,994 Region Association: None |
Are the T4 and T1 head studs interchangeable?
I see to be having a hard time finding a T4 (78mm stroke, 5.5" rods) head stud kit, other than the $400 RaceWare kit. There are tons of T1 head stud kits avail, just checking if they'll work. |
jcd914 |
May 25 2018, 08:48 PM
Advanced Member Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
Are other than stock head studs required for a stroker motor?
Jim |
Mark Henry |
May 25 2018, 09:50 PM
Are other than stock head studs required for a stroker motor? Jim He's got longer than stock rods, so he's going to need thick shims under the cylinders. I use 5.4 T1 rods and the stock studs can be used. I have nickies/JE's with those you need ARP for the correct clamping pressure. |
Lo-Fi Version | Time is now: 31st October 2024 - 07:24 PM |
