Biggles |
Member ![]() ![]() Group: Members Posts: 191 Joined: 5-September 13 From: UK Member No.: 16,353 Region Association: England ![]() |
Hi All,
Please can someone advise how i go about installing this Balupunkt Hamburg radio in my -6 car? It didnt have a radio when i bought it so I don't have a reference. I've been given a couple of brackets with the 'new' radio but i can't see how it's supported on the bulkhead or from above. I've included a few pics of what i've got, plus one from ebay which shows the U shaped bracket being screwed onto the back - is this right, and what else does it attach onto? thanks Chris. Attached image(s) ![]() ![]() ![]() ![]() |
dr914@autoatlanta.com |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,903 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None ![]() |
there is a factory blaupunkt u clip that hangs into the two round holes in the firewall bracket, and two clips that bolt around the knob shafts. Then the radio "snaps" in and you install the factory brickweave faceplate with double faced tape and then the radio trim plate then the knobs.
jdamiano |
Member ![]() ![]() Group: Members Posts: 335 Joined: 18-March 18 From: Jacksonville Member No.: 21,981 Region Association: South East States ![]() |
here is a picture of the clip. Not sure where you would buy one. I made mine. I also made two tabs that go on the knob shafts to sandwich the dash between my tabs and the faceplate.
Attached image(s) ![]() |
gcrotvik |
Member ![]() ![]() Group: Members Posts: 360 Joined: 16-December 09 From: Portland Oregon Member No.: 11,134 Region Association: Pacific Northwest ![]() |
here is a picture of the clip. Not sure where you would buy one. I made mine. I also made two tabs that go on the knob shafts to sandwich the dash between my tabs and the faceplate. Be aware there is a long and a short "C" clip. If you have a short depth Blapunkt chassis, the short clip may not be long enough. If you a long depth chassis. the short and the long "C" clip will work. The clip in the picture is the short clip I believe. Greg |
Lo-Fi Version | Time is now: 20th June 2024 - 06:25 AM |
