Mblizzard |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,033 Joined: 28-January 13 From: Knoxville Tn Member No.: 15,438 Region Association: South East States ![]() |
I searched but could not find the list of compatible gages and sending units.
With my sway I think I have a mismatch. Stock Gauge reads all the way to the “P” in TEMP but my MicroSquirt oil temp mounted in head only goes up to 190 F when the temp is on the P. Checked case with IR thermometer and got comparatively close numbers to the MicroSquirt reading. CHT never above 320. As a person the constantly scans the gauges I find this distracting to say the least. Have Tim’s lights in the gauges so would need to match the sensor. |
McMark |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,179 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None ![]() |
That temp gauge in the valve cover area seems unreliable to me. I know oil can collect up there, especially at sustained high RPM, but I'm doubtful it's 100% submerged in oil all the time. And that's a terribly inaccurate way to measure oil temp. It'd work for MicroSquirt as an indicator of when the engine is warmed up, but I wouldn't trust those numbers to accurately reflect actual oil temp. The IR thermometer is a similar problem. You're measuring the metal, not the oil. Those aren't the same.
Try warming up the oil with a drive, then pull the dipstick and IR measure the end that was in the oil. It'll probably drop temp quickly, so you'll have to be fast about it. I bet that reading is much higher than in the valve cover. |
Mblizzard |
That temp gauge in the valve cover area seems unreliable to me. I know oil can collect up there, especially at sustained high RPM, but I'm doubtful it's 100% submerged in oil all the time. And that's a terribly inaccurate way to measure oil temp. It'd work for MicroSquirt as an indicator of when the engine is warmed up, but I wouldn't trust those numbers to accurately reflect actual oil temp. The IR thermometer is a similar problem. You're measuring the metal, not the oil. Those aren't the same. Try warming up the oil with a drive, then pull the dipstick and IR measure the end that was in the oil. It'll probably drop temp quickly, so you'll have to be fast about it. I bet that reading is much higher than in the valve cover. Agree. It is not intended to measure oil temp just a warm up value for MicroSquirt. But for comparison purposes it provides a reasonable level of measurement to say the oil temp is closer to 190 F than to the meltdown temp indicated by the oil temp gauge. This combined with the IR says that then engine is operating closer to normal than a overheating condition. |
Lo-Fi Version | Time is now: 22nd June 2024 - 08:21 PM |
