> Dyno Run
sharper
post May 28 2018, 07:52 PM
I finally know what the output of my engine is after all these years. This is without any tuning. Now I just need to find someone who can tune it for the 3.5l piston and cylinders and evo cams that are in there.Attached Image
falcor75
post May 28 2018, 11:51 PM
Would be interesting to see the lambda curve overlaid on the graph to get an idea what the dip between 5 and 6 k depends on.
wndsrfr
post May 29 2018, 06:11 AM
QUOTE(falcor75 @ May 28 2018, 09:51 PM) *
(IMG:style_emoticons/default/agree.gif) get the data they stored on the runs and print out the air/fuel lambda curve on the chart....nice flat torque profile but shouldn't dip off...could prolly go to 6800 safely also....
falcor75
post May 29 2018, 08:22 AM
QUOTE(wndsrfr @ May 29 2018, 02:11 PM) *
Yes if it's a 3,5 with 3,2 fueling you are probably a bit lean where the curves dip, you should be able to get that taken care of. I'm not sure if Steve Wong has something or not, I used his chip in my 964 and got 252 hp at the wheels.
- Lo-Fi Version Time is now: 31st October 2024 - 07:28 PM
