Mueller |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,146 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None ![]() ![]() |
So I was helping Sandy with his original /6 yesterday , we put new Porterfield pads on his car.
Fronts are easy, however the rear I ended up putting the stock pads back on due to a few reasons: Large diameter pins wouldn't fit into new pads, options: Grind down pins or drill/mill the backing plate for larger diameter? Easy options, just not sure which is preferred. The bigger problem was that when retracting pistons for new pads which are about 1/8" wider due to being new we started to leak a lot of fluid and I got nervous if something like a seal was being damaged while screwing out the outer allen key? So, is it okay to keep turning the screw to make room for the new pads and then once the .008" clearance is achieved just tighten the 13mm nut with no more leaks? ![]() ![]() |
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 15,594 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
I also want to add something...
The venting clearance in the book is way too big. If you cut it in half to .004, you still get enough clearance for the brakes to function correctly, and the park brake works better. |
jcd914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California ![]() |
I also want to add something... The venting clearance in the book is way too big. If you cut it in half to .004, you still get enough clearance for the brakes to function correctly, and the park brake works better. (IMG:style_emoticons/default/agree.gif) It is not unusual to leak some brake fluid while turning the adjusters to retract the pistons or even when just simply adjusting the venting clearance. It should not continue to leak after you tighten the lock nut. Jim No |
Mueller |
I also want to add something... The venting clearance in the book is way too big. If you cut it in half to .004, you still get enough clearance for the brakes to function correctly, and the park brake works better. (IMG:style_emoticons/default/agree.gif) It is not unusual to leak some brake fluid while turning the adjusters to retract the pistons or even when just simply adjusting the venting clearance. It should not continue to leak after you tighten the lock nut. Jim No Thanks all.... Will watch the video later on. Sandy ordered new rotors today...his current rotors didn't look that good, lots of embedded metal or something was just off on them. Thanks. |
Lo-Fi Version | Time is now: 28th June 2024 - 10:33 PM |
