Mueller |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,146 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None ![]() ![]() |
So I was helping Sandy with his original /6 yesterday , we put new Porterfield pads on his car.
Fronts are easy, however the rear I ended up putting the stock pads back on due to a few reasons: Large diameter pins wouldn't fit into new pads, options: Grind down pins or drill/mill the backing plate for larger diameter? Easy options, just not sure which is preferred. The bigger problem was that when retracting pistons for new pads which are about 1/8" wider due to being new we started to leak a lot of fluid and I got nervous if something like a seal was being damaged while screwing out the outer allen key? So, is it okay to keep turning the screw to make room for the new pads and then once the .008" clearance is achieved just tighten the 13mm nut with no more leaks? ![]() ![]() |
Amphicar770 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,199 Joined: 20-April 10 From: PA, USA Member No.: 11,639 Region Association: MidAtlantic Region ![]() ![]() |
I had to use the air power burst on one if my stuck adjusters. Used a butterfly impact wrench. While 18v Milwaukee has replaced most if my air powered tools this required air. It's not about torque but rather the immediate burst of rpm.
Lo-Fi Version | Time is now: 28th June 2024 - 10:59 PM |
