euro911 |
Retired & living the dream. God help me if I wake up! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,851 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California ![]() ![]() |
OK, so I hadn't started the 'BB' for a while, but it was running fine the last time I did. I wanted to make sure everything was in fairly tip-top shape for Bill (Bill1963), prior to him taking custodianship a couple of weeks from now.
I wheeled a very large capacity (255A), heavy (170 lbs), fully-charged battery over to the car and ran heavy-duty jumper cables to the terminals and attempted to start her yesterday ... and nothing. I hear the fuel pump running, lights work, stereo works, etc. Next, I raise the lift and jumped across the (+) starter cable terminal to the solenoid terminal under the car ... and viola, it cranks just fine. I had my wife turn the key while I checked for voltage on the solenoid terminal, but found no voltage present there. I found and read a couple of old threads on starter issues, so I did the following: I checked the solenoid wiring from the switch (which is spliced at the bypassed relay box under the passenger seat - it's a '75) and that's fine. I check the relays on the relay board, burnish the contacts and reinsert - still not activating the starter (IMG:style_emoticons/default/headbang.gif) I also read that sometimes the tumbler mechanism doesn't turn far enough to fully engage the electrical terminals in the ignition switch, so I crank to the right as hard as I can and the starter finally engaged (for a brief second or so). I tried it again several times afterwards without any success. The ignition switch was replaced with a new one a couple of years ago and didn't have a ton of starting cycles on it ... so how is it, that just not being used for a period of time, that these 'new' switches seem to be failing? Where can we purchase a quality made switch these days? Signed, 'Frustrated' ... (IMG:style_emoticons/default/popcorn[1].gif) |
Porschef |
How you doin' ![]() ![]() ![]() ![]() Group: Members Posts: 2,170 Joined: 7-September 10 From: LawnGuyland Member No.: 12,152 Region Association: North East States ![]() ![]() |
100% Mark. Late switches are available through dealers and are Macht auf Deutchland so they should be good for, say, another 30 years?... (IMG:style_emoticons/default/confused24.gif)
Money well spent. |
Lo-Fi Version | Time is now: 29th June 2024 - 12:39 AM |
