Faulty Starter Switch(es) ? |
euro911 |
Jun 29 2018, 02:35 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,855 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
OK, so I hadn't started the 'BB' for a while, but it was running fine the last time I did. I wanted to make sure everything was in fairly tip-top shape for Bill (Bill1963), prior to him taking custodianship a couple of weeks from now.
I wheeled a very large capacity (255A), heavy (170 lbs), fully-charged battery over to the car and ran heavy-duty jumper cables to the terminals and attempted to start her yesterday ... and nothing. I hear the fuel pump running, lights work, stereo works, etc. Next, I raise the lift and jumped across the (+) starter cable terminal to the solenoid terminal under the car ... and viola, it cranks just fine. I had my wife turn the key while I checked for voltage on the solenoid terminal, but found no voltage present there. I found and read a couple of old threads on starter issues, so I did the following: I checked the solenoid wiring from the switch (which is spliced at the bypassed relay box under the passenger seat - it's a '75) and that's fine. I check the relays on the relay board, burnish the contacts and reinsert - still not activating the starter (IMG:style_emoticons/default/headbang.gif) I also read that sometimes the tumbler mechanism doesn't turn far enough to fully engage the electrical terminals in the ignition switch, so I crank to the right as hard as I can and the starter finally engaged (for a brief second or so). I tried it again several times afterwards without any success. The ignition switch was replaced with a new one a couple of years ago and didn't have a ton of starting cycles on it ... so how is it, that just not being used for a period of time, that these 'new' switches seem to be failing? Where can we purchase a quality made switch these days? Signed, 'Frustrated' ... (IMG:style_emoticons/default/popcorn[1].gif) |
rick 918-S |
Jun 30 2018, 03:24 AM
Hey nice rack! -Celette Group: Members Posts: 20,681 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
Check the relay board. More plausible the board is corroding that the switch failed.
michael7810 |
Jun 30 2018, 10:01 AM
Senior Member Group: Members Posts: 1,082 Joined: 6-June 11 From: Scottsdale, AZ Member No.: 13,164 Region Association: Southwest Region |
Check the relay board. More plausible the board is corroding that the switch failed. (IMG:style_emoticons/default/agree.gif) mine was doing the same thing and cleaning the relay board connector contacts seemed to have fixed it |
Lo-Fi Version | Time is now: 28th September 2024 - 05:07 PM |
