ambergris |
Newbie ![]() Group: Members Posts: 22 Joined: 2-June 04 From: Mountain View, CA Member No.: 2,145 Region Association: Northern California ![]() |
In my quest to clean up the shifting action on my 74 2.0L, I decided to rebuild the tranny. My first time doing something like this, and I thought it turned out pretty well. I think I have a leak at the speedo drive, but the grinds in 2nd and 3rd disappeared. Shifting was pretty good, and I was able to hit all the gears I intended to on my test run at first. (IMG:style_emoticons/default/smilie_pokal.gif)
But then the slop came back, and I found myself having a hard time finding 4th and 5th. I was giving the "pot of gears" a lot of stirring to find anything. I assumed I had to fine-tune my shift rod alignment. So I got back home and started playing with the alignment when POP! the shifter came totally loose. I thought I had lost a cone set screw or something, until I looked under the car. It looks like my shift rod came apart! It looks like there's a tack weld or something that came undone. (IMG:style_emoticons/default/headbang.gif) So now, I have a couple of questions: 1. Is it possible that this is what was causing my shift slop? 2. Are there any special considerations when getting this fixed? Can I just take the 2 peices to any body shop and ask them to re-weld it? Or this my opportunity to buy a welder and learn a new skill (IMG:style_emoticons/default/welder.gif) One step forward and one back again. Oh, and does anyone know what's going on with the JWest RennShift "Extreme Makeover"? I was looking at maybe getting one once I get this taken care of, and the site has sales suspended. Attached thumbnail(s) ![]() |
DJsRepS |
Member ![]() ![]() Group: Members Posts: 431 Joined: 4-November 04 From: Sarasota Florida Member No.: 3,060 ![]() |
You better hope there is not so much protective coating on the clutch side of that rebuilt tranny! Yea just line up the old spot weld and go solid weld all the way
Lo-Fi Version | Time is now: 28th June 2024 - 03:47 AM |
