Original Carpet - how to remove around steering column/rack, advice |
moldygreg |
Jul 9 2018, 05:22 PM
Stay Golden Group: Members Posts: 135 Joined: 13-December 12 From: Seattle Member No.: 15,253 Region Association: Pacific Northwest |
I may be too blurry-eyed and lacking cognitive thought.... be kind.
I also searched, but didn't come up with an answer. How do I remove the original carpet piece that has the grommet going though the U-Joint steering column/rack? Do I have to drop the rack? Seperate the U-Joint? Ideas for path of least resistance appreciated. Apologies in advance if this is a dumb question! (IMG:style_emoticons/default/smile.gif) Greg |
dr914@autoatlanta.com |
Jul 10 2018, 08:16 AM
914 Guru Group: Members Posts: 7,914 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
remove the lower dash, unplug wiper ts and ignition switch remove the four Allen bolts remove the 14mm at the firewall for the shift coupler, pull the steering column back pull the carpet off install the new and reassemble. DO NOT CUT THE ORIGINAL FACTORY CARPET
I may be too blurry-eyed and lacking cognitive thought.... be kind. I also searched, but didn't come up with an answer. How do I remove the original carpet piece that has the grommet going though the U-Joint steering column/rack? Do I have to drop the rack? Seperate the U-Joint? Ideas for path of least resistance appreciated. Apologies in advance if this is a dumb question! (IMG:style_emoticons/default/smile.gif) Greg |
Lo-Fi Version | Time is now: 29th June 2024 - 12:06 AM |
