Frame rails... |
Frame rails... |
Jeroen |
Aug 15 2004, 02:55 PM
914 Guru Group: Members Posts: 7,887 Joined: 24-December 02 From: The Netherlands Member No.: 3 Region Association: Europe |
Didn't get to work on the 914 as much as I hoped over my vacation, but still made some good progress over the last couple of days...
Frame rails in the engine comp. are stripped naked They still need some minor detailing here and there and the "hell holes" still need to be cleaned, but most of the hard work is done Tonight I welded the rear shock towers to the frame rails Quite a gap to fill... Attached image(s) |
Eric_Shea |
Nov 16 2004, 04:44 PM
PMB Performance Group: Admin Posts: 19,289 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
I'm going to revive this thread from August.
I looked at a bare tub today and it looks as though the longitudinal is spot welded to the shock tower along that seam that is clearly visable in Jeroen's 1st picture. It looks as though it is spot welded from the inside. I was able to look up into the shock tower and see spot welds where the longitudinal would terminate. Question 1: Is this correct? Has anyone seen inside the longitudinal at this point? Brad? Brandt? Jeroen? Question 2: That being the case, are you seam welding this area for strength? Question 3: That not being the case, did the factory forget to weld the longitudinal to the shock tower in this area? Question 4: Brandt, any further info on your procedure? Thanks in advance! E. |
Lo-Fi Version | Time is now: 22nd November 2024 - 11:22 PM |
