orthobiz |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,755 Joined: 8-January 07 From: Cadillac, Michigan Member No.: 7,438 Region Association: Upper MidWest ![]() ![]() |
BFO: Blinding (or Brilliant) Flash of the Obvious
Basically, if I can do it anyone can and like most 914 projects, it is possible to screw it up. Background: I'm sending the door card from my 1971 to be repaired. (IMG:http://www.914world.com/bbs2/uploads_offsite/farm1.staticflickr.com-7438-1531701156.1.jpg)[/url] First remove the two plugs at either end of the door pocket. Fingernails or a plastic spudge will do it. They are a little sticky, I guess so they are less likely to pop out. (IMG:http://www.914world.com/bbs2/uploads_offsite/farm2.staticflickr.com-7438-1531701157.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/farm1.staticflickr.com-7438-1531701157.3.jpg) Then, insert an Allen wrench (4mm? Mine are unlabelled!) (IMG:http://www.914world.com/bbs2/uploads_offsite/farm2.staticflickr.com-7438-1531701158.4.jpg) |
PanelBilly |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,825 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest ![]() ![]() |
Putting it back together can be a challenge. The nuts that clip into the door frame like to slip out of their spot requiring you to take everything apart. Best to secure them in place with a little spreading of the clip first.
Lo-Fi Version | Time is now: 28th June 2024 - 01:10 AM |
