> Frame rails...
Jeroen
post Aug 15 2004, 02:55 PM
Region Association: Europe
Didn't get to work on the 914 as much as I hoped over my vacation, but still made some good progress over the last couple of days...
Frame rails in the engine comp. are stripped naked
They still need some minor detailing here and there and the "hell holes" still need to be cleaned, but most of the hard work is done
Tonight I welded the rear shock towers to the frame rails
Quite a gap to fill...
Gint
post Nov 16 2004, 05:27 PM
Mike Ginter
(IMG:style_emoticons/default/agree.gif) Please? This is for my tub.
Hey Eric,
Brant posted this in his thread:
QUOTE(brant Posted on Nov 16 2004 @ 08:22 AM)
Jeroen,
this one is for you.
I mentioned this previously, but I used a plasma cutter to open the frame cavity and do some welding inside to brace the rear towers..... Then closed it back up.
You can see my welding seam.. Its kinda a big triangle (about 6inches long):
(IMG:http://www.914world.com/bbs2/uploads/post-2-1100618551.jpg)
Here is the other picture Brant referred to of the inside of the shock tower.
QUOTE(brant Posted: Nov 1 2004 @ 09:18 PM)
Here is the seam welding on the rear towers inside..
Jeroen, I mentioned this once a while back...  I don't have to tell you not to over look this area.  1/2 of the rear seams are inside.  You can't see them due to all the body filler the factory puts in there.  you can grind that crud out with a wire wheel and then get to them.
I don't have a pic of it, but I also cut open to access the frame end in the engine bay.  Right where it butts up to this tower.  We welded that and then closed the access portal back up.. Welded it closed and you can barely tell after a bit of grinding
here she is from beneath:
(IMG:http://www.914world.com/bbs2/uploads/post-2-1099369131.jpg)
This post has been edited by Gint: Nov 16 2004, 05:46 PM
Jeroen   Frame rails...   Aug 15 2004, 02:55 PM
Jeroen   Welded up... :welder:   Aug 15 2004, 02:56 PM
Jeroen   Top of the drivers side still needs to be welded, ...   Aug 15 2004, 02:58 PM
Jeroen   Last pic for now... I wanted to buy a better weld...   Aug 15 2004, 03:00 PM
watsonrx13   Damn, the trunk is GONE and the engine shelf... :D...   Aug 15 2004, 06:01 PM
seanery   Gotta have room for that 917 motor! :woohoo:   Aug 15 2004, 06:15 PM
Gint   Good lookin work Jeroen.   Aug 15 2004, 08:13 PM
Brad Roberts   Good job Charlie Brown :headbanger: Perfect pic...   Aug 15 2004, 11:56 PM
Lou W   Wow, I never realized how those towers are attache...   Aug 16 2004, 12:04 AM
Brad Roberts   You got it. The GT stiff kit pieces that go insid...   Aug 16 2004, 12:14 AM
jgiroux67   Is there a way to do this without cutting out part...   Aug 16 2004, 12:24 AM
brant   Damn.. nice job Jeroen. I plagerized some of your...   Aug 16 2004, 08:36 AM
Joe Ricard   Damn day lae and a dollar short. Wish I would hav...   Aug 16 2004, 11:13 AM
rdauenhauer   I confused :wacko: w/o seeing the original back ...   Aug 16 2004, 11:36 AM
Brad Roberts   It has small tabs that are folded over and spot we...   Aug 16 2004, 11:43 AM
Jeroen   Maybe this pic helps you get a better idea... Her...   Aug 16 2004, 05:07 PM
Eric_Shea   I'm going to revive this thread from August. ...   Nov 16 2004, 04:44 PM
brant   Eric, 1) Actually I have not looked inside a lo...   Nov 16 2004, 05:24 PM
Gint   :agree: Please? This is for my tub. Hey Eric, ...   Nov 16 2004, 05:27 PM
Gint   Thanks Brant!<...   Nov 16 2004, 05:30 PM
brant   Mike, one more thing and then I'll shut up a...   Nov 16 2004, 06:01 PM
Gint   I hear ya, but if I want to do it, now is the time...   Nov 16 2004, 06:09 PM
Eric_Shea   Me agrees with Brandt. Here's what we (Mike a...   Nov 16 2004, 06:14 PM
brant   I know I said that I'd shut up, but oh well......   Nov 16 2004, 06:23 PM
Jeroen   Ok, I'll try and explain best as I can... In ...   Nov 16 2004, 06:32 PM
Jeroen   If you wanna keep the firewall in place, like Bran...   Nov 16 2004, 06:56 PM
hargray2   So you are referring to all of the area highlighte...   Nov 16 2004, 07:11 PM
URY914   Jeroen, Isn't the sheet metal on the shock to...   Nov 16 2004, 07:16 PM
URY914   I'm going to cut my firewall out. and I'm ...   Nov 16 2004, 07:20 PM
Gint     Nov 17 2004, 10:30 AM
Jeroen   ...   Nov 17 2004, 10:47 AM
davep   I think a fully dissected set of views would be re...   Nov 17 2004, 12:41 PM
Jeroen   Here's the disected shocktower pic This is ju...   Nov 17 2004, 01:11 PM
URY914   That is a great shot.   Nov 17 2004, 01:14 PM
Jeroen   Some sawzall pics, courtesy of Mike Mueller Drive...   Nov 17 2004, 01:23 PM
Jeroen   drivers side front shoch tower   Nov 17 2004, 01:23 PM
Jeroen   drivers side front shock tower - close up   Nov 17 2004, 01:24 PM
Jeroen   firewall (passenger/engine)   Nov 17 2004, 01:24 PM
Jeroen   rear trunk, x-section of the dogbone, near the tra...   Nov 17 2004, 01:24 PM
Jeroen   last one... Targa/roll bar inner reinforcement   Nov 17 2004, 01:25 PM
Eric_Shea
  Nov 17 2004, 02:32 PM
Gint   Thanks Eric...   Nov 17 2004, 03:40 PM
SpecialK   Great pics guys! 'Saved' them all...   Nov 17 2004, 06:20 PM
nsyr   Anybody have any pics of the shock tower seperated...   Nov 17 2004, 07:05 PM
hargray2
  Nov 18 2004, 11:42 AM
Brad Roberts   Remove the cover. Weld stiff kit to frame rail. We...   Nov 18 2004, 11:51 AM
Gint   <...   Nov 19 2004, 02:24 AM
Gint
  Nov 19 2004, 10:44 AM
Gint     Nov 20 2004, 12:24 AM
Gint     Nov 21 2004, 09:05 PM
URY914   I have added bars from the shock tower down to the...   Nov 21 2004, 09:27 PM
Series9     Nov 22 2004, 02:34 AM
Jeroen     Nov 22 2004, 04:29 AM
Jeroen   Joe, I just noticed you cut the rear end of the tr...   Nov 22 2004, 04:30 AM
URY914   I want to stiffen the ear to the front (as seen in...   Nov 22 2004, 08:05 AM
Series9     Nov 23 2004, 10:05 AM
Gint   Anybody mind if I edit the title of this thread (m...   Nov 24 2004, 08:36 PM
URY914   I don't mind. :D   Nov 25 2004, 07:11 AM
Gint   We had a sawzall party yoday and I disected a fram...   Nov 27 2004, 06:13 PM
Gint   This is the opposite side showing how the inner fe...   Nov 27 2004, 06:15 PM
Gint   I'm the proud owner of that section of tub, so...   Nov 27 2004, 06:26 PM
Brad Roberts   That is ok. I'm still waiting to breath. I...   Nov 27 2004, 06:30 PM
Gint   The one I just posted the pictures of was a 72 (02...   Nov 27 2004, 06:31 PM
Eric_Shea
  Nov 27 2004, 06:33 PM
15 User(s) are reading this topic (15 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 22nd November 2024 - 11:00 PM
