Firewall sound pad options-i see several ideas, What do you have/what would you do? |
DRPHIL914 |
Jul 23 2018, 10:57 AM
Dr. Phil Group: Members Posts: 5,806 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
I have seen some options out there,
1. Stock 2. After market a. AA pad b. Rix914parts- modern material, light weight c. dynamat d. 914rubber pad. 3. -others?? Also in the cab, the rubber sound deadener( I assume this was only for sound or vibration, since it is rubber I doubt it did much for heat) - I pull this out it was stock and am trying to decide if I should put it back in again or do dynamat or something like this on the inside firewall before putting the backpad back in |
Mikey914 |
Jul 23 2018, 05:46 PM
The rubber man Group: Members Posts: 12,711 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Stock will hold water and is pretty heavy, however it is stock. We are making a new one with a water repellent material that is light weight and has a rubber skin that looks like the OEM and has sound deadening properties. I'll get some pics up tomorrow.
Mark |
Lo-Fi Version | Time is now: 25th September 2024 - 10:45 PM |
