Firewall sound pad options-i see several ideas, What do you have/what would you do? |
DRPHIL914 |
Jul 23 2018, 10:57 AM
Dr. Phil Group: Members Posts: 5,806 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
I have seen some options out there,
1. Stock 2. After market a. AA pad b. Rix914parts- modern material, light weight c. dynamat d. 914rubber pad. 3. -others?? Also in the cab, the rubber sound deadener( I assume this was only for sound or vibration, since it is rubber I doubt it did much for heat) - I pull this out it was stock and am trying to decide if I should put it back in again or do dynamat or something like this on the inside firewall before putting the backpad back in |
bbrock |
Jul 23 2018, 07:58 PM
I'm leaning toward reusing my stock mat but spraying the back and edges with Flex-Seal to keep it from absorbing water. My hunch is that deteriorating seals are part of the rust equation with these mats, and just knowing it might be an issue makes it easy to keep an eye on and make adjustments before damage is done.
Lo-Fi Version | Time is now: 25th September 2024 - 11:00 PM |
