tsvo |
Member ![]() ![]() Group: Members Posts: 123 Joined: 30-January 16 From: Chicago Member No.: 19,616 Region Association: Upper MidWest ![]() ![]() |
I have a 1973 1.7. I noticed a small puddle on my garage floor this morning. I cleaned it up and have not seen any more. I looked under the car and I think it is coming from the small screen next to the oil filter. Can anyone tell me what this is and what I need to fix it? It seems tight, is there a seal? It was above 90 degrees when I drove it. Could it be related to heat?
Any help is appreciated Terry Attached thumbnail(s) ![]() |
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 14,999 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
Yes. Look up as many fake-German swear words as you can, because you're going to need all of them. Mostly when dealing with the upper mounting bolt, because access to swing a wrench or ratchet handle (if I remember correctly) is a super huge PITA.
Also, get everything in that area out of the way if you can. Definitely remove the filter and let the flange drip until it stops, because it's annoying to have oil dripping on you while you try to unbolt that flange. --DD |
Lo-Fi Version | Time is now: 24th June 2024 - 07:16 AM |
